How to display bend line in sheetmetal model?
yseo
8-Gravel
I made planar feature in sheetmetal part.
And added flange wall on edge.
After applied flat pattern I would like to display bend line.
If impossible I would like to display original egde in flatten state.
Is it possible?
1 ACCEPTED SOLUTION
mbonka
(To:yseo)
Hello Yong Bok Seo
if your flat pattern was created succesfully, then should be created "bend axis" (in my opinion the same like bend lines). See attached picture.
In praxis l´m using this bend axis to sketch lines for engraving ---> it makes work easier for guys from workshop.
Hope it helps...
Regards
Milan Bonka
2 REPLIES 2
mbonka
(To:yseo)
Hello Yong Bok Seo
Hope it helps...
Regards
Milan Bonka
yseo
8-Gravel
(To:yseo)
Hello Milan Bonka
I am really happy to get your good solution.
Thanks a lot
Regards
