How to fix any sketch element?
fuzzylog1c
1-Newbie
I want to fix the position of an element of my sketch (e.g. a line or a point) in such a way that by defining any distance to it from any other elements such elements must move (and not the fixed one).
Is there a simple way to do it?
2 REPLIES 2
You can select a point or line, Right Mouse Button --> Toggle Lock
rburgess-2
(To:fuzzylog1c)
1st, make sure your sketches contain at least (1) coordinate sys (sketcher),  then (2nd) set the horizontal or vertical constraint on the csys. Your sketches should be much more stable.
