How to fix any sketch element?
Newbie
I want to fix the position of an element of my sketch (e.g. a line or a point) in such a way that by defining any distance to it from any other elements such elements must move (and not the fixed one).
Is there a simple way to do it?
Re: How to fix any sketch element?
You can select a point or line, Right Mouse Button --> Toggle Lock
1st, make sure your sketches contain at least (1) coordinate sys (sketcher),  then (2nd) set the horizontal or vertical constraint on the csys. Your sketches should be much more stable.
