In sheet metal i'm having one part. It Unable to get a flat pattern in CREO 3.0.
Its an alternate method but gives you the same result what you want.
Please find below image for your solution.
Please try with the features in the model tree what i used.
Jimmy
Thank you for your support jignesh vadalia..
Hi jignesh vadalia
I tried your solution but i'm not able to flat pattern. if i go to flat pattern the surface is not selecting. Can you sent me that part what are you trying.
Hi Raj,
please send me your email ID.
I will send it to you.
Jignesh
Hi Raj,
hope you got the solution..
If yes the please mark the answer correct.
Jignesh
Hi Raj,
Jignesh
Are you asking about this? Anyway, this is discussed in depth at this link.
