How to hide notes
How to hide notes
I would like to know how to hide some sorts of notes like geometrical references, welding notes, atc. on parts and asseblies
thnx for help
Tags (4)
8 REPLIES 8
Re: How to hide notes
Hi!
There should be a layer that allows you to hide the itens that you need.
If that itens are anotations you should see a anotations feature in modeltree then you can show/hide.
in this case it is just a Fillet weld feature and i cannot find it in layer tree.
For me there is no need to show it on models at all - isnt there some posibility to disable it in config.pro?
Hi!
Can you share an example so I can try here?
Hi, for the 3D environments you should be able to turn these of / toggle their display with the "Annotation Display" button. This will however not hide them in the drawing if they are shown there.
What I like is to create a default layers with rules in my start part, in this way you can have all symbols automatically put in to a specific layer, which makes it easy to hide or un-hide them in the drawing/model. Remember to make the layer filter associative if you want it to filter already existing items...
I just saw now that i have those rules in my layers too. i need a file to try to hide those with no layr or no rules
Hugo, how can i send a zip file over this wep page?
yes you can
but i dont know how 🙂
