How to hide the word "Distance" while using measuring tool?
ychannaiah
3-Visitor
Hi All,
I'm trying to take some snap shots of the measurements from one of the part. But I don't want the words like "Distance" or "Angle" or "Total Area" etc.,
to be prefixed befor the values. How can I do it?
Pls help and thanks in Advance.
Yogesh
1 ACCEPTED SOLUTION
Yogesh,
Measure parameter names cannot remove/hide from result pop-up.
4 REPLIES 4
You have to resize column until it disappears. You mean that?
Yes, I mean it.
And I'm not talking about the Words in the "Measure Distance" window...But instead the words in the pop-up that appears when you measure. See my attachment in the post.
Yogesh,
Right. You have to modify image. Or put that parameter in a drawing.
