How to indicate a hole as a clearance hole or a tap hole in a drawing hole table in Creo Parametric?
MichaelDzurak
What is the best method to indicate a hole as a clearance hole or a tap hole in a drawing hole table when using standard holes or custom hole (*.hol) with parameters?
A1 is a through hole that is tapped.
B1 is a through hole that is a clearance for a bolt
Both are shown as the same type of hole in the hole table.
0 REPLIES 0
