How to indicate in repeat region relation assigned or calculated weight
STEVEG
I have a table that is reporting the Mass among other things. However, some of our models have a density assigned and some have the actual mass assigned in the PRO_ALT_MP_MASS parameter. I also have two columns in the table that I am trying to get to report whether the information was assigned using the weight or calculated from the density.
My thought was to (then realized why this doesn'twork correctly) write that if the asm_mbr_pro_alt_mp_mass exists then to mark the assigned column with an X and the computed column with a dash. Otherwise reverse the X and dash. In all cases though the first column is marked with an X.
if exists("asm_mbr_pro_alt_mp_mass")
MP=asm_mbr_pro_alt_mp_mass*rpt_qty
AW="X"
CW="-"
else
MP=asm_mbr_pro_mp_mass*rpt_qty
CW="X"
AW="-"
ENDIF
Is there another way to show whether the weight was calculated or assigned?
Steve G
0 REPLIES 0
