How to use Feature_ID in Relation for suppress/Exclude single feature?
Newbie
Please Help if anyone having experience on it.
14 REPLIES 14
Re: How to use Feature_ID in Relation for suppress/Exclude single feature?
you cannot suppress feature using relations. You have to use Pro/PROGRAM functionality.
MH
Martin Hanák
Dear Martin,
I knew it and also i use from that side but i want to do using relation.
I am sorry I do not understand what do you want to know.
MH
Martin Hanák
i use pro-program functionality for suppress feature at particular relation.
But i want to suppress feature with the use of Relation and Parameter.
‌I think they want to set up an IF-ELSE-ENDIF section in Pro/Program that controls whether a feature or features are suppressed or unsuppressed based on the value of a parameter.
please provide detailed example explaining your need. For example: Attach model and describe, how do you want to ""drive" it. Use combination of  pictures and text when providing the explanation.
MH
Martin Hanák
Highlighted
Kevin
You are right.
I want to use IF Endif formula for suppress feature but i want to use by Relation and Parameter not using by Pro-Program.
The only way to suppress features is with Pro/Program.   All the of the decision making logic can be in relations and parameters, but the actual suppress and resume can only be performed by Pro/Program.
ss3
Regular Member
(in response to TomU)
please can suggest how to create parameters, and how to write a pro program to suppress a part.
Please got through complete below example how am i expecting.
Example: Consider XXX.asm is my master assembly. XXX-A is sub-assembly & is having n number of parts, i need to write a program such that among n number of parts, only 3 sheetmetal parts should be controlled.(SHT1, SHT2, SHT3)
That is, if WIDTH of my master assembly is (WIDTH<=1000MM & WIDTH>=850MM), SHT1.PRT Should resume. SHT2 and SHT3 should get suppress.
If WIDTH of my master assembly is greater than 1000mm(WIDTH>=1001 & WIDTH<=1600), SHT2.PRT & SHT3.PRT should get resume and SHT1.PRT should get suppress. (i dont want to use pattern or family table as SHT1/2/3 are of different sizes)
can Width be defined in increment or decrement value of 25mm? how the program should be?
Below are the internal component id:
ADD PART SHT1
INTERNAL COMPONENT ID 48
END ADD
ADD PART SHT2
INTERNAL COMPONENT ID 49
END ADD
ADD PART SHT3
INTERNAL COMPONENT ID 52
END ADD
I TRIED THIS: (BUT GETTING ERROR)
IF WIDTH=1200
errorLogical expression expected.
ADD SUPPRESSED PART SHT2.PRT
errorExtra symbols found - ignored.
ENDIF
THANK YOU
