I am having difficulty selecting parts while modeling.
SOLVED
Newbie
It often takes several clicks on a part before it is selected. Anybody know a fix?
Re: I am having difficulty selecting parts while modeling.
Oddly enough, that may be a graphics card issue. You can try updating your graphic card drivers.
You can test if it is a graphics card issue by adding graphics win32_gdi to your config.pro.
If the problem goes away with that option, it's a graphic card problem and you will definitely need to find a better driver.
Don't forget to remove that option once you are done testing.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Try using the Alt button on your keyboard, Select from the Model Tree if you are in assembly with multiple parts also works.
Using the Alt key only makes so I can select edges, surfaces, etc. It doesn't allow me to select the part. Also my assemblies are generally composed of a lot of duplicate parts so using the Model Tree doesn't make things faster.
Steve Williams
I beg to differ. I have Creo 4.0. The alt button highlights the part model in assembly. Using just the cursor highlights the feature. Regards
