I don't understand the problem
Highlighted
Guest
Hello! I don't understand this problem. I consider two slide carriage and one of them give this problem. I used a rigid link to connect the interior faces
Highlighted
Re: Simulation results not showing
you can test:
Highlighted
This happens because the results window is not reading the results directory.
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
