I have problem regarding Hole table placing in Drafting
NaveenKumarGong
Hello Everyone,
I need two or more hole table in a single draft.
For example:
I have created hole features in front face and back face of a part for required depth and Coordinate system also created in both sides. when I am placing hole table in Draft "FIRST PLACED VIEW" able to generate hole table, other face side hole table not able to generate (May be the first view only in active view of Draft... How to active other view of Draft).
Please help me to resolve this problem.
Thanks and Regards,
Naveen Kumar Gongu.
1 ACCEPTED SOLUTION
Thanks for your reply MartinHanak and MartinHanak.
I resolved the problem by taking cosys from graphics window in the drawing itself. But the problem is the cosys is showing away from actual display while selecting to place Hole table.
Thanks and Regards,
Naveen Kumar Gongu.
Naveen,
I guess that hole axes must be normal to screen and also coordinate system Z-axis must be normal to screen and pointing towards you.
Upload some example data, it helps to understand your situation.
Martin Hanak
Martin Hanák
Dale_Rosema
(To:MartinHanak)
From my experience you need a separate hole table on a plate for holes machined from the front and from the back. If there are any side holes, they would have their own table also.
Each of these require a 0,0 coordiate point also.
Thanks, Dale
Thanks and Regards,
Naveen Kumar Gongu.
