I need to measure distance between two axis but get results in X,Y,Z, coordinates.
bcooper
1-Newbie
I need to measure distance between two axis but get results in X,Y,Z, coordinates. I saw that this was doable in Creo parametric 2.0 but can't find it in Creo Parametric 3.0, any thoughts?
1 ACCEPTED SOLUTION
dgschaefer
(To:bcooper)
It's in the center of the measure dialog.
LinkedIn
4 REPLIES 4
dgschaefer
(To:bcooper)
When I use either the distance or summary measurement tools, I get a distance between any two axes.  The summary tool also gives me the angle.
Are you specifying a coordinate system in the projection box?  That's the only way I get the X, Y & Z.
LinkedIn
I don't see that option.
dgschaefer
(To:bcooper)
LinkedIn
Perfect, thanks for your help.
