I am trying to create a model with an inheritance as the first feature after the base datums. If I leave it as MERGE, it works fine. If I change it to INHERITANCE, it fails. I've attached the model I am trying to use for the inheritance. I didn't try to vary any of the dimensions or make any other changes. Just simply created the inheritance feature in a fresh empty model. I tried with another part and it worked fine, so I don't think I am doing it wrong. There must be an issue with the model but I don't know what it is.
Thanks for the suggestion, guys. As it turns out, since the model I was bringing in is sheetmetal, the new part has to be sheetmetal, too, but I left it as the default solid.
I didn't download the model to look at it, but is the model accuracy different between the 2? Often times, if a model has a specific value set in accuracy to regenerate, the inheritance will fail if the values do not match. Just something to check.
-Matt
Don't forget to mark your answer as correct for those who may search on this in the future.
