Ok,... I'm reaching now because I'm basically clueless here... but try opening one of your instances and check the dimension in question to see if it has the same "D" callout as the generic.... it should but I guess you just never know. When you have eliminated the possible, whatever is left, however unlikely, must be the truth. Good luck.
Chris Benner
Autodesk ® Expert Elite
