Is suppress by layer exist in ProE?
ptc-3191571
I have seen some threads having discussion on this topic earlier WF 2.0.Does this functionality exist in WF 5.0 M 060.? If yes please let me know how can I use it.
Hello Rahul,
If you would like to use the possibility, to set the layer status programatically, then yes this is possible.
Function: ProLayerDisplaystatusSet
Status to HIDDEN
This is also possible in WF3 and 4.
Best Regards
DOMINIK HARTINGER
APPLICATION ENGINEER
CADS GmbH Tel.: +43 (0) 7262-9396-3660
Technologiepark 17, A-4320 Perg Fax: +43 (0) 7262-9396-493660
www.cads.at <u>www.ptc-apps.com</u>
Hello Dominik,
Will this operation make features available on this layer hidden?
Rahul,
I don't know if Dominik's response got what you needed, but I thought
you were asking a different question, so just for clarity's sake, I
thought I would throw out a thought about suppress using layer. In
standard Pro/E, you can suppress by layer by using the status tab in the
find window.
In JLink, you can loop through to get the layers, then interrogate the
layers. Some (crude) example code:
try{
//Grab current session and model
Session curSession = pfcGlobal.GetProESession();
Model curModel = curSession.GetCurrentModel();
ModelItems allItems =
curModel.ListItems(ModelItemType.ITEM_LAYER);
FeatureOperations solidOps =
FeatureOperations.create();
for (int i = 0;i<allitems.getarraysize();i++){<br/>
Layer curLayer = (Layer)allItems.get(i);
if(curLayer.GetName().equalsIgnoreCase("LayerNameToCheck")){
ModelItems allLayerItems =
curLayer.ListItems();
for(int ii =
0;ii<alllayeritems.getarraysize();ii++){<br/>
ModelItem curItem =
allLayerItems.get(ii);
if(curItem.GetType()==ModelItemType.ITEM_FEATURE){
Feature curFeatureToSuppress =
(Feature)curItem;
SuppressOperation suppOp =
curFeatureToSuppress.CreateSuppressOp();
solidOps.append(suppOp);
Solid curSolid = (Solid)curModel;
curSolid.ExecuteFeatureOps(solidOps, null);
NOTE: Since you are using WF5, in order to utilize the
ExecuteFeatureOps method, you have to use the Pro/E config option
regen_failure_handling (set to resolve_mode). Otherwise you'll get a
toolkit error (according to PTC).
At least that is one way of doing it. Hope all is well!
Brian Krieger
Peterbilt Motors
