Is there a way to set wood hatches on a section ? Can we expect such hatch types in further Creo releases ?
jkoeberle
2-Guest
Hi forum,
After a few searches on the net, I realize that there are no hatch types for wood included in Creo. Is there a way to create non-regular hatch patterns ? I see that I'm not the only one looking for this possibility. Does someone have tricks to do it or can we expect some PTC improvements in this area ?
mender
6-Contributor
(To:jkoeberle)
Until recently, cross sections could be filled with a solid color, or hatched with one or more lines defined by angle/spacing/offset/style.  Look to Creo 4 for support for non-linear hatch styles.  Wood in particular may be found by Retrieve - customer_patterns.pat from the System Patterns directory - Wood.
I think they have added support for other formats to Creo 4.x
Creo MBD and 2D Detailing Product Update
Creo now supports industry standard hatch pattern files
–*.pat file format
–Hundreds of patterns
mender
6-Contributor
(To:jkoeberle)
how to add .pat file to my creo. I have downloaded from the internet and now i want use it in creo 4.0. Please help me.
Ok, I am currently working with Creo 2. It will soon be time to upgrade to Creo 4 then...
Thanks to you both for your answers.
Jerome.
