When preparing to go from ProE WF4 to Creo 3 a PTC rep said that there were hundreds (I think he said over 400) enhancements going from WF4 to Creo 2 'while no features have been removed' (paraphrased). For those who are using Creo2, we all know that is simply not true.
Purpose of this Document is to provide a one-stop-place to get the following
Anyone has permission to modify this document. Please Add/modify/or cross out anything below this line and discuss everything else below the thread:
Functionality Removed:
Although available through customizing the ribbon or using the new command search, the following features have been removed from the default UI, giving concern to some that PTC is contemplating removing the features altogether. PTC, the following features are still used and appreciated:
Functionality that PTC has fixed and is now available:
I did not yet get all of the 'dehancements' listed here but hope to return to put more in.
Remember just click on edit document to add more 'dehancements' that you have found.
Rather than delete ideas if they are possible, simply changing the text style to strikethrough with an explanation is probably a better option so people can see the workaround.
CS129458 https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS129458
confirms that the Pipe feature command has been hidden, so if you want to use it in Creo 2 & 3, then you may want to set the config.pro option :
enable_obsoleted_features yes
Any idea why PTC is obsoleting this feature?
I guess it might be because they intend to replace it with 'curve through points', but I'm not sure...
Interesting. I use curve through points a lot, but it really is not a new tool and has been around for a long time.
Referring to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS39340
Menu option "Show > Use Model in Tree" in drawing mode is back in Creo 2.0 M150 and 3.0 M030
I have been wondering about that one but had not locked it down if it was completely removed, or just lost in a particular tab or RMB menu.
Thanks for the comment and update. I look forward to having it back, as I used it more frequently in WF and have had to do other works around since then!
Pause and Resume was removed from the show dimensions
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS207966&source=Case%20Viewer
Starting with Creo you can no longer customize the File Menu
1 - Dragging a Step or Iges into active part used to have the option to append, now it does not.
2 - Renaming a component on assembly or drawing mode is possible on Creo 2, but not in Creo 3.
3 - On assembly mode, you could select one component and regenerate it instead of regenerating all assembly. This was usefull for big assemblies. In Creo 3 that option has gone.
4 - Fast detailing has died with Creo 2. In Creo 3 it takes more time to out dimensions.
1-3 are big losses in Creo 3. I generally like Creo 3, and there are workarounds, but I miss these.
