Looking for an advanced Draft command technique
Re: Looking for an advanced Draft command technique
When using the "split by split object" inside the draft feature, you can select more than one draft hinge.  Then set the side options to "draft sides dependently".  While this can work well on simple geometry, it's not very robust when the geometry gets complicated.
In your case, most of the part looks good, but the two sharp corners get a little funky.
Can't you get the right result with the "Split" --> "Split by draft hinge" option?
