Mapkey Syntax?
doneill
Mapkey Syntax?
I'd like to minimize the number of lines in my Mapkey code...
For example, today I have a line that selects "node12" (recorded cursor selection)
                                   Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node12`;\
I know I can search the model tree but I wonder if there is a way I can just specify the Feature Name in the Tree...
Like...                      Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `FRONT`;\
I know that doesn't work but I wonder if there is a command that will let me do that.
8 REPLIES 8
Trebla
(To:doneill)
Hi Doneill,
If you don't like to search for planes in the model tree, you could use Rename from Model Properties, save the mapkey using this alternative way...
@Trebla wrote:
Hi Doneill,
Hi @Trebla ,
I tried to create a mapkey using your suggestion ... unfortunatelly with no success.
Martin Hanák
Trebla
(To:MartinHanak)
Hi @MartinHanak
Yes, I was wrong, useful mapkey is not possible with Rename...
doneill
(To:Trebla)
Thanks... I never noticed you could change the names there...
The Search Tool works fine... (see the code I posted in  Mapkey - Select a Plane without using the Mouse )
(Martin - I have a question... I like how when you post code, it looks like it's in a text box... how did you do that?)
I'm just trying to expand my knowledge of Mapkey Code...
Are there instructions somewhere on  Mapkey Commands & Syntax?
I figure there are probably some good tricks out there...
Trebla
(To:doneill)
Hi Doneill
a lot of mapkey tips here
doneill
(To:Trebla)
Thank you!
use following button to insert text box.
Note: PTC does not provide any official information concerning mapkey syntax.
Martin Hanák
