Mapkey for reading an input.txt from a specific directory for the regeneration of the model?
SOLVED
Highlighted
Amethyst
Is it possible to make a Mapkey so it reads an input.txt file (with value of my models parameters) to use it in the "Read File" regeneration option? The file is in a very specific directory, I does not move and has a fixed name (input.txt)
Nic.
1 ACCEPTED SOLUTION
Re: Mapkey for reading an input.txt from a specific directory for the regeneration of the model?
Yes
First step is to create a part (or assembly) with one or more INPUT parameters. That will make the "Read File" available when you regenerate your part.
Then just record a new mapkey, click on Edit --> Regenerate --> Read File --> Enter the full filename
It will look something like this (I have named the mapkey qq)
mapkey qq @MAPKEY_NAMEqq;@MAPKEY_LABELqq;~ Command `ProCmdRegenPart`;\
mapkey(continued) #READ FILE;c:\temp\input.txt;\
mapkey(continued) ~ Activate `main_dlg_cur` `main_dlg_cur`;
9 REPLIES 9
Yes
aaaaaahhhhh... thank you!!! So that was the trick!! Put the whole path to the file!!
Thank you again!
Nic.
Could you please elaborate this a bit? This "read file" option when regeneration sounds interesting but I can't follow what's happening here.
You wrote "click on edit-->regerenate" - Edit where? In the ribbon - Model - Operations - Regeneration there is no option for "read file", and neither is in Parameters - Edit.
Andreas
"First step is to create a part (or assembly) with one or more INPUT parameters"
Does your part/assembly have any INPUT parameters? If so, then the "Read File" option will become available.
I'm still on WildFire 4.0, so that's why I refer to "Edit" --> "Regenerate"
For Creo 4, that should look something like "Model" --> "Regenerate"
Yes, still on WF4, you've read that right 🙂
Or just simply click on the regenerate icon and you will have the menu with:
Current Values (the one stored in the model at the moment you clicked on the"regenerate" button)
Enter (which will show the available parameter of which value you can enter from the keyboard)
Read File (which reads these values for the model's parameter from a text file. You will have inside the text file lines with the names of your parameter and the values something like
Param1 = 1 (if Param1 was defined as "number")
Param2 = "String value" (if Param2 was defined as a "string")
Param3 = Yes (if param3 was defined as a "Yes_No" value)
Yeah, you already lost me there. What is an input parameter? Our models have parameters, some are pdm driven, some are relation driven, some are to be changed manually. Type can be Real, Integer, String, Yes/no. But INPUT? I can think of that only in drawings, when a model parameter, required by the frame via template, is not present.
Try to look at this post
Drawing Program User Guide, Tutorial and Hands-On Workshop
which was created primarily for
Drawing Program which is DIFFERENT from Pro/PROGRAM
but you will find very useful links for start using Pro?PROGRAM, including a Hands-on workshop (with that I started to familiarise with Pro/Program).
Nic.
See the attachment (cilinder_example.zip) of this post https://www.ptcusercommunity.com/message/474748#474748
OK, thanks to both of you.
LiveWorx Call For Papers Happening Now!
