Material orientation setup
rperez-5
I am trying to figure out how to use the material orientation menu on creo parametric 2.0. I created a new orientation and selected my coord. system but I don't understand what the 1, 2, 3, X, Y, Z and "rotate about" are for. I would like my material to be oriented along the X axis. can someone help me set this up?
Randy
ehaenen
(To:rperez-5)
Hi Randy
This contraption is just meant for people that accidentally define their material coordinate system in the wrong direction.
If you want your material to be oriented along the x-direction, the "1"direction must be the local x-direction as in this picture. If you happen to want the 1-direction to coincide with the local z, feel free to change the selection.
Hope this helps
Erik
Thanks Erik. I have the material orientation correct but I got a message saying orientation is ignored for isotropic material. Would using the same young's modulus for E1, E2, and E3 give me accurate results? I only have a modulus of 10400 ksi for my material.
Randy
ehaenen
(To:rperez-5)
Hi Randy
If you do that, you don't have to do that. To be more clear, if it is correct that E1=E2=E3, than the orientation doesn't matter and you can use isotropic material anbd you don't need a material coordinate system. In  stead, you can use that coordinate system to show stresses (σxx , σyy, σzz   ) where x and y and z are according to that coordinate system.
Erik
Thanks for your help on this Erik.
Randy
