Measure the thickness normal to a point
Newbie
I have over 30,000 points that I read into a file from these points I need to measure the thickness of a very large complicated part normal to each point. I also need to read out the normal thickness at each point and the location to a spread sheet. Does Creo2 have the capability of doing this and if so how?
2 REPLIES 2
Re: Measure the thickness normal to a point
...pack a lunch.......and a Snicker's bar......
Highlighted
Take a look at this discussion :http://communities.ptc.com/message/199198#199198
I think that it would be useful for you.
If I were you I would use Rapidform XOV or Geomagic Qualify Probe for this task.
They are perfect for such kind of work.
And Reverse Engineering Extension from PTC is not suitable for inspection.
LiveWorx Call For Papers Happening Now!
