Measurement tool
nhanratty
2-Guest
Measurement tool
All
We have a 3D curve defining the path of an exhaust pipe which is created using a swept blend.
I believe if you click in the projection field and select your desired CS it will do what you want.
LinkedIn
Thanks to Janet and Doug who both suggested selecting the 'projection' field and then selecting the coordinate system I want to use.
This was the first thing we tried but it made no difference...apparently because we are on Creo 2.0 m050.
Janet confirmed that it works in build code m080.
Thanks again to all.
Neal Hanratty
Engineering Systems and Standards Manager
Terex Materials Processing Group
T +44 (0)28 8241 8769
F +44 (0)28 8225 2740
M +44 (0)75 3495 2739
E neal.hanratty@terex.com<">mailto:neal.hanratty@terex.com>
