Metal Grating
ptc-6373552
Metal Grating
Hi Creo Community,
I'm running creo 5.0.4. I'm trying to make some metal grating like the pictures below. To give you an idea of scale, a single hole is about 1" wide and about 3" long. I need to create a sheet of this about 40ft long and about 10ft wide. How would you recommend doing this? is there a way to use a cosmetic feature or perhaps get creo to treat it as a single feature not 20,000 features such as in a fill pattern? Or perhaps as a material/texture?
Thanks!
11 REPLIES 11
BenLoosli
23-Emerald II
(To:ptc-6373552)
What do you intend to do with the file? Just a pretty picture or something that will be cut and mated to a structure?
Hi BenLoosli,
I have a big part part (see below) that needs to have this grating across the entire top where the yellow solid plate is shown. I can add it to this part or can create a new part and add it into an assembly. Image 1.jpg
One way to actually model this would be to use geometry pattern and even a pattern of a pattern. I'm attaching a brief presentation I did on this. It's from an old version of Pro/E so you'll have to forgive the actual GUI selections.
WOW! Awesome, I will try this out. Thanks for the tip!
rburgess-2
(To:ptc-6373552)
Another time saver in newer releases of Creo, (I'm using Creo 4.0 M140), is the "identical" option. This alone cut over 75% from regen time in large patterns. (See attachment)
BenLoosli
23-Emerald II
(To:rburgess-2)
Must be an advanced copy since the PTC Product Calendar only lists through M130 to be released in April 2020 and the latest release was M100 in July.
rburgess-2
(To:BenLoosli)
M040 ><
The "identical" option for a pattern was already present in Wildfire 4.0 🙂
rburgess-2
(To:HamsterNL)
We installed Creo 4.0 M040, (got it right this time), in 2018 but, didn't find the identical setting until +/- 2019... Yay team!
kdirth
20-Turquoise
(To:ptc-6373552)
I came across a method referred to as turbo pattern.  This helps a lot with regeneration of complicated feature patterns.  Should help with simple ones also.
TURBO PATTERN (Patterning complicated features without overly slowing regeneration)
  • Create single feature
  • Copy surfaces down to base of feature
    • Hint: Select single surface on feature, hold shift and select bounding surface(s) and release shift. This should select all of the surfaces of the feature.
  • Pattern surface copy
  • Solidify original surface copy
  • Pattern solidification
rreifsnyder
(To:kdirth)
this is exactly what the Geometry pattern does except that it waits to do the solidification till the end because that is actually the slowest part of feature creation.
