More datum weirdness - set axes
davehaigh
11-Garnet
I created two axes to define symmetry in two directions on my part and set those to dimensions.
I can't show the axes in the view. This used to be possible in Wildfire 4.0.
Any ideas? Other than creating two more axes.
[cid:image001.png@01CE8DCA.F9D1CEB0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
1 REPLY 1
Got an answer:
I found the method to show a set datum axis in views.
You have to select Display Datum Graphics from the axis properties box. It is not selected by default.
[cid:image001.png@01CE8DDA.E244F500]
Brian Liebelt
Mechanical Designer
Nuclear Weapon Engineering Program
Defense Technologies Engineering Division
Lawrence Livermore National Laboratory
(925)422-8783
David Haigh
