NEED HELP TO PROPERLY CALLOUT A THREAD NOTE
BriGuy
11-Garnet
After starting at a new job a few weeks ago, this is the first time I've added a threaded hole to a model.  Instead of the proper callout of 4-40 UNC-2B.... is just reads Note_0, Note_1, Note_2, etc.  Under Add A Note in the feature, the checkbox is checked.  Also, the parameters are filled in for the features as well.  Is there a way to toggle to show the correct thread note??
Kevin
(To:BriGuy)
Check your config file for the option model_notes_as_labels and set it to no.
BenLoosli
(To:BriGuy)
It would help if you identified what version of Creo you are using and the build release?
What works in one build may be broken in another.
Kevin
(To:BriGuy)
BriGuy
11-Garnet
(To:Kevin)
Thank you Kevin.  That's what I was looking for.
