Need to build repetitive curve in a sketch
SOLVED
Amethyst
I am needing to build a sketch that the curve needs to follow an exact pattern.  I have attached a sketch that shows the basic curvature. (As it is freehand the shape is not exact however)
The pattern of curvature needs to follow a point placement like this.  The initial point is at X=0 and Y=+.06.  The second point on the curve would be X=+.5 and Y=-.06.  The 3rd point on the curve would be X=1 and Y=.06.  Etc...
I want to build a curve where I don't have to manually enter the dimensions as the size will extend for close to 50 inches.
My initial thought would be that Relations might be the way to go, but I have no experience with this and don't know if it would be capable of what I am looking to do.
Tags (1)
Re: Need to build repetitive curve in a sketch
I'll try again tomorrow. Trying to remember the formula just now.
X= 40*(t*720)
Y= 4*sin*(t*360)
Z=0
In this case 40 is the wavelength.
720 is 2 cycles
I think 4 is amplitude for y
Z is zero because it's in a single plane.
Difficult when not in front of a car screen to check.
10 REPLIES 10
Still looking this over online.  I haven't pieced this together but I am now wondering whether this can be done as a relation at all within a sketch.
I am seeing examples how using a variable section sweep can influence different shapes but haven't seen a simple straight line oscillating curve that would result in the basic sweep shape of the curve on my initial post.
HI, Use curve from equation.
Datum\Curve\curve from equation. Example can be tailored from below.
Rcrerar-2:  The images you attached aren't showing.  I will see if I can find the location you are suggesting but if there is an easy way to see these images it would be great.
X= 40*(t*720)
Y= 4*sin*(t*360)
Z=0
720 is 2 cycles
This is excellent!
I just did find a video that showed roughly what I needed and proved this out.
I will check to see how your numbers differentiate.
This is a little fudgy so it may be that your numbers are closer in line than the formula I was using.
Just Checked the formula I used.
x=50*t
y= 4*sin(t*720)
z=0
curve would be 50 units long and total height is 8 units crest to crest. This produces 2 cycles if you want more then each cycle is multiple of 360.
If it is not a sin curve then the maths needs working out.
Have fun.
Subsitute 'sin' for 'cos' in the formula & you get another variation of the curve.
Worth a mention.
rcrerar:  Here is the formula that I went with.  This worked great.
I will be able to use this pattern in the straight stretches, but unfortunately I can not use this for twisting around a large radii in our die.  With that I will be developing a different technique involving a pattern and some fillets.
When you extrude this feature it looks a lot like a sun chip.  Unfortunately I can't bend this feature at a specific large radii while maintaining the tilt I will need.
John:  I did for a while consider the cosine function for doing a bend, but in the end I knew it would be a bear to maintain a specific bend radii as well being unable to carry through the proper inclination.
In the end I know that I can still use this for the straight stretches in my die.  It gives a beautiful result.
"I will be able to use this pattern in the straight stretches, but unfortunately I can not use this for twisting around a large radii in our die.  With that I will be developing a different technique involving a pattern and some fillets."
I am not sure what you mean exactly by your statement but would the attached image help?
