Numerical method errors with Flatten Quilt?
cweigold
Good afternoon all,
I've just started using the Flatten Quilt feature this week and I have noticed some interesting behavior.
If, before I flatten, I measure the length of a curved edge of a quilt along the curve (the one with PNT4 for example), I get some value. If I then flatten the quilt and measure the same edge length (not the distance point to point), the value is slightly different by a few hundredths of a millimeter. Is this due to computational errors while solving for the flattened quilt?
Secondly, let's say I have a quilt, but I want to trim off part of it and then flatten that trimmed part. The intersection curve in the attached image shows where the trim will be. I trim and flatten and all is well. I can measure the length of the curve with PNT4 and I get a value. But wait, if I use Bend Solid to put those intersection curves on my flattened quilt and then measure the length of the same curve, it is not the same length either in linear distance or by curve length. Shouldn't both of these methods give me the same result?
WF3
M140
-Chris
It gets even worse Chris, when you get into very small variance. If you
take a half sheet and flatten the quilt, the sheet is not symmetrical
about the center line and if you want to apply an extrusion in the very
corners of the sheet there is even more distortion. I think this is
caused by whatever computations ProE has to do to get this tool to work.
Rather than "Flatten" sheet, it ought to be "Crushed up and pulled
roughly flat" sheet.
BTW You'll notice also that ProE doesn't know whether to call flatten
sheet geometry, a "Solid Bend" or a "Bend Solid" in their Help
documentation.
Richard A. Black
Lead Engineer
Eaton Corporation
16900 Aberdeen Road
Laurinburg, NC. 28353
