Offset lines in exploded view drawing
dbreen
1-Newbie
Hi everybody,
I'm making an exploded drawing view which contains several offset lines. I've no problem creating the view in exploded state including the offset lines, however the offset lines are not only shown between the parts but are also overlap the parts as shown in the attached image. Does anybody know what to change in order have no overlap?
Thanks in advance!
Dave
2 REPLIES 2
Dale_Rosema
(To:dbreen)
Here is one idea to vote one. Not sure if this is exactly what you are looking for:
Smart Explode line - Assembly mode
Here is another:
explode state line - same display in shadind mode
Thanks, Dale
Thanks Dale!
The last idea, explode state line - same display in shading mode, describes the problem i'm encountering. Unfortunately there isn't a proper solution than to work around the problem as i understand from the posts.
Thanks for your response!
Dave
