One mapkey to multiple mapkey
Participant
Hello everyone,
I have mapkey for certain task for one part. How to convert this mapkey into multiple parts.??
Thanks in Advance.!!
7 REPLIES 7
Re: One mapkey to multiple mapkey
If I am undestanding your question, you want to split one mapkey into multiple mapkeys.  This can be done by modifying the config.pro file.Capture.JPG
Locate the mapkey in the text.  Copy the first line of the mapkey and paste where you want the split.  Rename the mapkey (highlighted text).  Save file.  Changes will take effect after restarting CREO or importing confg file in configuration editor.
You can also copy the entire mapkey, rename, and divide to keep the original.
Creo is an endless adventure: Always more to learn.
I think that OP wants to apply the mapkey to the list of parts as a single batch. He does not want to open files one by one (eg. 100-times) and apply mapkey.
Martin Hanák
Please clarify what you are trying to do.
Thanks.
If you want to run a mapkey on multiple parts, you could use sBatch by USG Professionals.
http://www.usgprofessionals.nl/engineering/professionals/segmenten/plm-cad/software-download
Hi there,
I'm having this issue.
I want a mapkey that changes the material of a group of items, particularly a library of fasteners, in a single batch.
Can someone please help me?
Best regards.
@BFrancio wrote:
Hi there,
Best regards.
you can use:
  • trail file
  • Distributed Batch
Unfortunately both methods are not intended for beginners 😞
Martin Hanák
Thank you for your response.
I will search for sollutions based on this trail file.
Best Regards,
