Hello there, same thing happens when you are opening a family table and you mistake the level or folder you want to open from, the you cannot roll back or go to an upper level in the open manager window, you need to close it and go to file-open again. I know map keys do the trick (block the sun with your thumb kind of trick). But pro/e should take those 2 simple option into account Regards
