Parameter maximum value
Level 12
Hello
If we create a string type parameter, what max number of characters can be set for a value of parameter?
Is it possible to store 300 characters as a value of parameter... If yes, what is the solution...? If no, is there any alternative for this solution..? Note we cannot use ... Parameters only we need to use due to dependency of other programs.
Any idea would be of great help.
Thanks in advance....!
Ketan
Tags (1)
Re: Parameter maximum value
Creo hard limits parameters to 80 characters and there is currently no way around this.
https://www.ptc.com/en/support/article?n=CS61011
What are you trying to accomplish with a 300 character parameter string?
You can create 4 parameters to capture the information, then concatenate them into a string for placement on a drawing.
We need to pass parameter value to other progame and that mapping is there for only parameters. Not for note...
Integration wasn't thought out too well.
Can you pass multiple parameters to your other program and then do the concatenating?
Correct but unfortunately that is not in our control. ... Same scenario we conveyed that we can provide many parameters but there also having problems as they want fix number of parameters but our parameters count changes with characters required for parameter values..
