i want to do a part list. In every of my parts I added parameters like wight and perimeter. I want this parametrs to appear in the part list. I read that I should add this parameters to the tree column which I did, and they should appear when I add the table, but they don´t. I´m also not sure if for it to appear I need to add the table from file.
Has someone an idea?
Thank you very much.
Edna
A parts list is only in an assembly file. Do you want that information at the assembly level?
You need to create a BOM table and add a column for the weight and perimeter and then use asm.mbr.<name_of_parameter> in those columns.
Garcia,
if you upload example data file, then I can help you.
Martin Hanak
