Parametrically merge multiple point sketches for point pattern, Creo 2.0
SOLVED
Regular Member
I have multiple datum point sketches that I would like to merge into a single sketch for patterning a hole.  I don't want Cntl-C/V the sketches together because construction lines overlap and get messy.  The point pattern only allows selecting 1 sketch at a time.  Does anyone have any suggestions?
Re: Parametrically merge multiple point sketches for point pattern, Creo 2.0
A pattern can only reference one sketch.  I'd redefine the last sketch to add the other points in and delete the earlier sketches.
If you want to keep the sketches separate for some reason, you can create a new sketch and duplicate the points in it, aligning all the new points to the earlier sketches.  Then if the old ones move, the new sketch will update.  If points are added or removed, however, the sketch driving the pattern will not update automatically.
Doug Schaefer | Engineering Manager
Crow Works
Crow Works
