I have created a family tree in a part.
lets say the family members are called -1,-2,-3,-4,-5.
I have a feature pattern of a cut.
On the -1 I will only have one cut.
On the -2 I will have the pattern set to 2 instances.
I do not know how to do.
For -1 I can not set the pattern to 1 instance.
I also tried to supress the pattern but then the referenced cut feature will also be supressed.
Is there a way to do this in Creo?
