Hi - I hope someone has an answer to this. I am trying to create a boat load of datum points to use as monitor points within a FloEFD analysis. I want each of these to have a unique name which I can define. I understand how to create a pattern table and import my list of points, however I can't figure out how to add unique names to these points.
PS I have about 700 points to upload so manually editing each one to change the name in the model tree is not an option.
If you can help then thanks in advance...
I know that it has been almost a year, but I came across a work around in another post. You can change the default editor from Pro/Table to Excel. Look at Andy's comment in this product improvement:
http://communities.ptc.com/ideas/3526#comment-11868
Thanks, Dale
