HI guys
is there a way to peck tap a hole. Had a look in parameters but can't see anything. Do I have to have more than one tapping sequence at varying depths.
thanks for any help
mick
Michael,
Did you get any responses on peck tapping? I would think if you were rigid tapping you could retract to the retract plane and reenter the hole without too much trouble and tap to a different depth. It would require multiple tap cycles though for each hole I think. not sure? I would have to try it.
if you are just talking multiple holes that have the same pitch but vary in depth you just make a new hole set with in the sequence and change the depth for each set.
Steve
HI steve
was thinking of tapping a single deep hole. Sounds like I have to have more than one sequence at varying depths.
Thanks michael
Michael,
That was my thought. I have never tried anything like that but I don't see why it wouldn't work with multiple sequences at varying depths. Either that or thread mill the tapped hole unless it is rediculously deep.
Maybe you should turn it in as an enhancement request for peck tapping.
Steve
