Pierce constraint in Pro/E and Creo?
Participant
Do anyone know how to constrain part of a sketch to geometry which intersects the sketch plane?
I've got a video here of this being done in SolidWorks: http://www.solidworkstips.com/content/index.php/solidworks-tips/46-01-pierce-relation
11 REPLIES 11
Re: Pierce constraint in Pro/E and Creo?
Hello David
Here is short demo of Coincident Constraint
Video Link : 2062
Vladimir
Best Regards,
Vladimir Palffy
Hi Vladimir
Thanks for the response. That only seems to work with the end of a curve though. What I want to do is snap to the point where a curve intersects the sketch plane.
Hello David
If you need move your sketch to intersect plane you can offset sweep profile with dimension or use Trim At.. functions (RMB)
Vladimir
Best Regards,
Vladimir Palffy
Thanks, good tip.
If it was the edge of a solid or surface, rather than a curve, would it have to be converted to a curve with Copy, or is there another way?
Thanks again
Copy and paste is a good technique
Best Regards,
Vladimir Palffy
To assist with this, I've attached a part. The idea is to line up the circle with the line where it crosses that plane. Would the Intersect command be relevant here?
Hi, I'm out of the office - I will write to answer next week.
Have a nice day.
Vladimir
Best Regards,
Vladimir Palffy
Hello
Here is my solutions:Move Sketch to other (new) Sketch Plane
Video Link : 2066
Vladimir
Best Regards,
Vladimir Palffy
David,
Not sure if this is what you are looking for, but I have attached a model I created in WF 5.0 where I created a spline sketch. I then invoked the sketch tool again this time while setting up the second sketch plane, I selected the point command and placed a point on the first spline curve, and on the datum plane (could be any surface though). After creating the point, I then selected the datum plane tool. I placed the Datum plane to go throughthat point, and to be normal to the original spline curve. After completing this plane, I allowed sketcher to use this for the sketch plane, and then created the circular sketch. It is pretty neat when I use Dynamic Edit, I can watch the second sketch stay tied to that intersection of the curve and plane, and also observe the curve remains normal to the spline at all times.
Hope this is helpful to someone.
-Greg
