Hi , maybe i’m just a dreamer but i was wondering if there is such a feature or mapkey possible to set up , that prints all the drw files associated with currently open assemble , another simple solution would be if you could just select drw files in workspace and print them from there but I can’t see that option , surly there has to be a way to avoid printing them one by one
Thanks for any help that u can offer
Michal,
Take a look at Distributed Batch, it's a seperate install on the Pro/E intall disk.
You can use it to batch print, export (drawings, parts, assemblies) to alternate file formats, and with the latest run mapkeys against files in your work space or local directory.
Hope this helps,
Don Anderson
Michal,
Hope this helps,
Don Anderson
Hello Michal,
have you tried Don's suggestion? It sounds like exactly what you are searching for (minus the dream that the system automatically fetches all related drawings)
If you find it working for you, please let the community know and mark the thread as answered (click Correct Answer in Don's post).
Gunter
