Pro/E and Citrix
Highlighted
Level 1
Pro/E and Citrix
I've been asked to look into this for some of our remote users on a slow
WAN.
Has anyone tried to use Citrix to actually run ProE (2001) and make
changes for several clients?
I was told to look into Citrix and it's "Speedscreen". We currently use
Citrix for users who perform query/locates only.
My thinking, before I go to painstaking lengths of work...is ProE still
has to run on the Citrix server.
With several clients running it at the same time, it is going to come to a
crawl if it can even handle that.
Has anyone tried this, success, failure?
What were the server specs?
Do you use another solution?
TIA
Rick Hill
MCAD Admin
EMERSON Network Power
Voice: (440) 246-4756
Fax: (440) 246-4881
This e-mail is intended only for the addressee named above.
As this e-mail may contain confidential or privileged information,
if you are not the named addressee, you are not authorized to
retain, read, copy or disseminate this message or any part of it.
