Pro/PROGRAM - reading input values from file
SOLVED
Highlighted
Emerald IV
Hello to all,
I have a part containing simple program (I am using Pro/PROGRAM functionality). I want to read input values from file. Unfortunatelly I cannot find the description of format for such input file. PTC Help and PTC Knowledge Base didn't help... Do you have some tip or link to PTC source ?
I use Creo Parametric 2.0 M020.
Martin Hanak
Martin Hanák
1 ACCEPTED SOLUTION
Highlighted
Re: Pro/PROGRAM - reading input values from file
Hey Martin
Try this :
I assume you have the Pro/Program part ..... but I'll add it in case anyone else misses this step
In Pro/Program:
INPUT
DESIGNER STRING
ANY_NUMBER NUMBER
END INPUT
DESIGNER is a parameter of STRING type
ANY_NUMBER is a parameter of REAL NUMBER type
In the text file:
DESIGNER = "you"
NUMBER = 22.9
When you regen you get the pop-up that wants to know where the values inside the INPUT statement are coming from.
Select Read File and input the name of the text file
Voila!
5 REPLIES 5
Highlighted
Would it help to output a few files and see how they are formatted? Maybe a point file and a relations file?
Highlighted
Hey Martin
Try this :
In Pro/Program:
INPUT
DESIGNER STRING
ANY_NUMBER NUMBER
END INPUT
In the text file:
DESIGNER = "you"
NUMBER = 22.9
Voila!
Highlighted
Hello Jody,
thank you for your answer. Your solution works well in Creo Parametric 2.0 M020+. I wish PTC will add this information into their Help Center...
A little correction for other users:
Text file contents:
DESIGNER = "you"
ANY_NUMBER = 22.9
Best regards
Martin Hanak
Martin Hanák
Highlighted
where do i put the txt file on my system? desktop? my documents?
or can i change the default location for these files?
i'm running creo parametric 3.0 with windchill 11
Highlighted
You can put the TXT file anywhere you want, for example c:\temp\, as long as you provide the full filename (with extension) to the TXT when you are using the "Read File" option.
