Problem in using pallet feature and also in Copy/Paste
ptc-5231774
I need the two points to coincide simultaneously so as to change the scale from 14.30 to some other number... i cant change the scale manually by trial-error method and zoom it to see whether it's coinciding or not ... i'm able to coincide any one pair but not both!! Using coincide constrain gives me conflits Untitled.png
1 ACCEPTED SOLUTION
Just drop the symbol sketch anywhere and then constrain it.
Just hit the check mark and it is now simply a sketch where you can change whatever you want.
