Problem with saving as JPEG
SOLVED
Regular Member
Hello everyone,
today i discovered a little problem. When i tried to save a part to JPEG file, it apeared that it has purple gradient in the picture even though i have my background set to pure white color. I have also discovered that it only appear when i set my resolution to anything higher that 100 DPI, everything higher what 100 DPI will include the gradient colors in the picture.
Thanks in advance.
Re: Problem with saving as JPEG
try adding following option into config.pro
graphics   win32_gdi
Martin Hanák
15 REPLIES 15
What version and build of Creo?
I did a 600dpi jpeg with white background in Creo4 M080 and it came out fine.
When was the last time you rebooted your workstation?
Im using Creo 3.0 version M040. Im working on a laptop. i dont understand why is this happening. I have checked all the settings i have nothing set to purple, at least i think.
Are you using some sort of render? The purple looks like the top of a "room wall" since it cuts off below the part and there is a "room" that has a purplish hue
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
No im not rendering, as i said i go - save as a copy - JPEG - and it does this. Honestly i dont know, u might have a point in the "room" thing. Im using university start tools so i dont know what my teachers putted into the start tools. Is there a way to turn that "room wall" off ?
Reboot the laptop!!!
Didnt work ... still have purple gradient background
Make sure your display style is set to shading or shade with edges and not shade with reflections or shade with render.
Usually it's pretty obovious a room is turned on, like in my image but maybe it's zoomed in.
Steve Williams
Its not the shading ... i have shading with edges always on.
Do you think it is a syscol kind of thing or the problem is somewhere else ?
