Problem with thickness
designer1966
I created a part with revolve feature with thicken sketch in WF 5.0. The thickness is 4 mm. When I want to change the thickness to 2mm, I receive message that this is out of range 10.09-1462.67. How can I correct the feature's thickness?
Hello
the problem is the accuracy. (ratio between dimensions) go to file->propriety->accuracy change it 0,0012 to may be 0,0008
regenerate and see what happens
best regards
Hello
best regards
What Pierre is referring to is that you get into difficulty when there is a large relative disparity between the size of a feature and the overall size of the model. If changing the Relative value doesn't work, you can also try changing to Absolute accuracy.
Just a little more detail, if you haven't done this before:
You change to Absolute through Edit/Setup/Accuracy, but in order to do this you need to set the config option enable_absolute_accuracy to YES. You can also set default_abs_accuracy to YES if you wish.
Thanks David and Pierre,
I changed relative accuracy of part and reduce thickness without problem.
