Problems Creating a Bevel Groove Weld
SOLVED
Highlighted
Regular Member
weld.JPGAs shown in the picture above, I have no problems creating fillet welds and bevel groove welds when parts butt together as shown in the attachment.
But I can't get it to add a bevel groove weld when 2 parts "tee" into each other. If you reference the picture you can see that I had no issues with creating the edge prep for this weld. But I can't get it to create the bevel groove weld for the parts that "tee" together. Using the "location" tab I think I've selected every combination of surfaces and edges but still having problems.
If anybody has some helpful advice please let me know.
Thanks, Steve
1 ACCEPTED SOLUTION
Highlighted
Re: Problems Creating a Bevel Groove Weld
@sducotey-2
You may try create a curve on one of the surfaces and use that as location and for other side use edge something as in image
2 REPLIES 2
Highlighted
@sducotey-2
Your suggestion is the solution. Thank you.
LiveWorx Call For Papers Happening Now!
