Hello everyone, I have a simple question. I am sure it can be done but I have little experience with restricted parameters other than setting up drop-down boxs.
I have a parameter that has a value - ****** (xxxx-xxxxxxxxxxxxxxxx)
Is there a way I can filter this out to just get ****** as a parameter. (Please note that the ******* are different lengths.)
I would love to just stop before the "("
Any help is appreciated.
Cheers
RCN
I think you can do this simply, as long as the ***** stuff doesn't contain a "(". Let's say you have two parameters:
stringIN = "******* (XXXXXXXX.XXXXXXX)" stringOUT
You want to use EXTRACT to set stringOUT to just the stuff before the "(". If the case is as simple as I've stated, that is done like this:
indexEnd = SEARCH ( stringIN, "(" ) IF indexEnd > 1 stringOUT = EXTRACT ( stringIN, 1, ( indexEnd - 1 ) ) ENDIF
Note: If there's no "(" in stringIN, or there's no text prior to the "(", stringOUT remains unchanged. If there is a space between the beginning of stringIN and the "(" and you don't want it, use ( indexEnd - 2 ) instead of ( indexEnd - 1 ).
Ken (and others here) is way better than I am at programming, but, you could make your parameter that reads "xxxx-xxxxxxxxxxxxxxxx" a sum of 2 other parameters. For instance, we would have a part that is comprised of the cage code (5-digits), separated by a dash, from the vendor part number. So, you could make parameters that were named "COMBINED_PART_NUMBER", "CAGE_CODE", and "VENDOR_PART_NUMBER". The relation COMBINED_PART_NUMBER = CAGE_CODE + "-" + VENDOR_PART_NUMBER. I believe that's the syntax, my license server is down.....again.....so I can't check my example parts.
EDIT: Up and running again...finally. Yup, the syntax is correct. The quotes are needed for text strings (whatever you want to say, a space, a dash etc.), the plus sign "adds" them, and the parameters (for their value) don't need quotes. I use this a lot for my library fasteners.
Best of luck!
