Dear Sir,
I have problem to create outer design of dish. By using trajpar relation sd=5*sin(3600*trajpar)+sd,
but didn't get required design so please help suggest the proper relation formula.
Please anyone give me urgent solution.
What is the value of SD?
Sorry, that's a trick answer... you have a circular argument.
You are defining SD and you are using SD in the right side.
The community was getting re-arranged so new messages were getting pushed far off the most recent.
That seems to be done with for now.
Typically sd is followed by a number to tell which dimension it refers to.
Yes of course 🙂 I was reading it literally. As in "sd" as a variable not the symbolic name of an exiting dimension.
sd value is 29.4
And how do we solve the circular argument?
Here's what I would expect
sd4= 5*sd5
Here's what I would not expect
sd = 5*sd
Knowing the value of sd is garbage in the second example.
but sir twisting fillet does not formed in dish by using given relation.
Upcoming October 2019
Regional User Groups
