Relations in WF4 - Insert a text file
JWayman
Good morning,
I have searched for an answer, but I can't find one. It's probably out there, though...
We have a Yes/No parameter in our StartPart called 'Keypoint_drg'. If the parameter is set to 'Yes', I would like to insert, automatically, the contents of a text file into the drawing.
I got as far as:
>>>if KEYPOINT_DRG == yes
keypoint_text == " "
else
keypoint_text == "NOTE: THIS DRAWING IS A KEYPOINT DRAWING ONLY.
error Unmatched quotes
THIS DRAWING DOES NOT CONTAIN ALL INFORMATION TO
error Extra symbols found - ignored.
MANUFACTURE THIS PART.
IT MUST BE READ IN CONJUNCTION WITH THE PRO/ENGINEER
MODEL DATA FILE LISTED BELOW:
&model_name .PRT , REVISION &PROI_REVISION, VERSION &PROI_VERSION
error Invalid number in relation.
3. UNLESS SPECIFIED OTHERWISE, THE TOLERANCE BETWEEN
ANY FEATURE IN THIS PART AND ANY OTHER FEATURE SHALL
BE THE DEFAULT TOLERANCE.
NO DIMENSIONING SCHEME IS IMPLIED IN THE CAD MODEL
endif<<<
Clearly, the relations editor is not keen on multi-line values in its quotes. Is there a way to include line-feeds in relations?
I have the requisite text in a notepad file, but I can't work out how to write a relation to make a parameter equal to the contents of a text file.
Any suggestions?
WF4, M220
John
John,
Try adding a backslash at the end of each line "\" as shown below. This indicates a line continuation to the program.
"NOTE: THIS DRAWING IS A KEYPOINT DRAWING ONLY.\
THIS DRAWING DOES NOT CONTAIN ALL INFORMATION TO\
MANUFACTURE THIS PART. ............
Thanks, Art.
I tried this, but I got the error message 'exceeded line length'. This even if I only extended the message by a single line.
I remember having used the \ in long relations previously, with some success, but it doesn't seem to help with notes.
John
John ,
Have you tried using =="this text" +"that text" + "the other text"
Otherwise, this has a bit more of what you may be looking for.
http://communities.ptc.com/thread/39088
