Remove Material on a Wrap feature?
Newbie
To whom it may concern,
I need to remove material from a Wrap feature on a cylinder.
I've been trying to get this done, but apparently Creo doesn't recognize further actions for the Wrap feature. Why would I need that feature if i'm not able to extrude or remove material from it?
Please, someone fluent on these PTC enigmas, HELP!
There is a picture attached for more information.
CC
5 REPLIES 5
Re: Remove Material on a Wrap feature?
Not sure why the Wrap feature isn't usable - what are you trying to do with it?
In anticipation, it should work as a trajectory for a swept feature.
There is a lot to be considered in your request.
A lot of sculpting is done with surfaces rather than solids.  Trims, merges, and intersects all work to manage each face of your design.  Once merged into a closed boundary, it can be solidified.  Or maybe a constant thickness offset?
Hello David,
I'm trying to make a slot with that shape.
I'm willing to use any other method in order to get this done, feel free to suggest.
Thank you,
CC
Highlighted
Hello Antonius,
I'm trying to make a slot with that shape. There's a pin that must slide normal to the trajectory of the slot.
I have no idea on how to make it. Feel free to suggest any method.
Thank you,
CC
Cruz
I actually ran into this problem a little while ago. You have everything correct in your model tree, now you need to add a sweep:
- The trajectory will be your wrapped sketch
- Then create the sweep section by clicking the sketch icon:
  - Make sure your section is at equivalent or greater than your wall thickness
  - Click the green check mark to accept the sketch, click 'remove material', and you should be good to go!
Rob
